file permission error while using vista
HI
In using vista  .I am getting file permission error in create text file.wats the reason?
kavi
(2,906 Views)
When you post a question, it would help readers answer your questions if you mentioned the LabVIEW Version you are using, a screenshot of the error and possibly the VI that makes this error occur.
(2,904 Views)
In which directory do you want to create the file? Vista doesn't like users messing around in the root drive (C:\), in the Windows folder, in the ProgramFiles folder and probably a few more.
Daniel
(2,898 Views)
Labview 8.6
kavi
(2,884 Views)
hi karpaga,
You can give more details - no charge for that.  Can you tell us the exact error msg?
(2,870 Views)
