file size limitation?
I have a large data file that is continuously being added to. I want labview (in windows XP) to tell me the size of that file as it is updated, but there seems to be a 4GB threshold (I am using a U32 variable to display the size, so this makes sense). What I want to know is this - is there a way around this, or do I have to limit my file size to 4BG? Thanks!
(2,647 Views)
> file size to 4BG?
Checkout the OpenG Toolkit on www.OpenG.org -> OpenG Toolkit ->
Downloads. On the sourceforge page you can get from there, is a
LargeFile library for Windows you can use to do that.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,647 Views)
I ran into this same problem when using the database connectivity toolset. On a win2000 machine, the .mdb file size was limited to 1GB. I changed my DSC application to store the data in the CITADEL database. CITADEL handles all of the file naming and size issues internally.
(2,647 Views)
