filter sine signal
Hi. i need to know how can i filter a sine signal.
I need to be able to know when the high sine begins (see image attached) and when this dignal finish.
but if i use the Signal Duration tool it gives all the signal value, i mean, it does not make difference between noise and signal.
Best regards
(2,975 Views)
Hi Peqdram
Could you send me the VI and the set of data that you are using?
Best Regards
Coamín Cruz
NI México
(2,728 Views)
(2,725 Views)
