filtering data sent to write to measurement file
Hi everyone, I was wondering how to implement a "filter" which prevents data to be written to the "write to measuments file" function.  Say if the incomming data is a 0 (DBL), hwo to prevent it from being written?
(2,489 Views)
Accepted by topic author baseball07
Use a case structure.  Put your write to measurement file inside a case structure, probably in the TRUE case.
(2,486 Views)
Put the write inside a case structure and select the case wth the output of =0? from the comparison palette.  Note that many times a DBL can be very small, ~ 1E-15, but not exactly zero due to the way numbers are represented in binary in the computer.  As a result, zero comparisons often do not work the way people sometimes expect. Comparing to a range near zero may be better.
Lynn
(2,485 Views)
