filtering out the delayed signal
i am using two Usrp 2920 devices and two omni-directional antennas with labView software, so the receiver receives two composed signal one of them is delayed and i want to filter out the delayed one.
(2,678 Views)
Hope you need to share the acquired data (Both Original as well as Delayed)
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,655 Views)
Hi mo.ma.9966
Welcome to the forums! Do you have some code you can share? Are you having some sort of error or problem when you're trying to run your application?
If you can be more specific with your questions and also provide some more information about your requirements and your application, we'll be able to help out and provide some recommendations. Thanks!
Jason O.
Jorr-El
Systems Engineer
Testeract: Automated Test Specialists
(2,630 Views)
