05-15-2014 05:45 AM
Hi, Experts :
I have a set of data (x,y,z), and the distance of each set (x,y,z) to a centre (X0,Y0,Z0) is caluclated by
f(x,y,z)=Sqrt( (x-X0)^2 +(y-Y0)^2 +(z-Z0)^2 )
I need to find a set of (X0,Y0,Z0), which can minimise the maximum of f(x,y,z)
in Excel, I can use Solver and take Mean(x,y,z) as start values for (X0,Y0,Z0),
using GRG nonlinear Method, I can find a minimum set of (X0,Y0,Z0). see aattched zip file for data and Excel file.
is there any way I can use LabView to do the same?
could Nonlinear curve Fit be used? and how to implement?
any suggestion is more than welcome.
thanks for your time
Xiaofeng
05-15-2014 08:13 AM
Check out the Mathematics>>Optimization palette. My choice would be the Downhill Simplex, but there are several other VIs on that palette which would also work.
05-15-2014 09:27 AM
thanks for your quick reply. I did try Downhill Simplex, but could not fingure out how to setup the VI.
see my trial one. any suggestion?
05-15-2014 11:49 AM - edited 05-15-2014 11:56 AM
xgatc wrote:I have a set of data (x,y,z), and the distance of each set (x,y,z) to a centre (X0,Y0,Z0) is caluclated by
What do you mean by "minimize the maximum"? (There will be several maxima in the solution).
Maybe you want do fit to a sphere instead?
05-15-2014 12:10 PM
Yes, it is actually to find minimum radius for sphere. I am using LV2012, and I could not find this call
any idea where I can get this?
many thanks.
05-15-2014 12:30 PM
05-15-2014 12:45 PM
05-15-2014 05:31 PM
HI, altenbach
you are right, the "fitting on a sphere fit.vi " is not what I am after.
thanks for the suggestion. I will have a look .
