find a value in a boolean array
Hey I have a boolean array with 500,000 values and I need to find the only one thats true. Is there an easy way to find this value?
Message 1 of 25
(12,535 Views)
Search 1D Array works fine with boolean arrays.
Message 2 of 25
(12,526 Views)
Search array?
Do you just want to find it (get the index) or do you also need to verify that there is only one?
Message 3 of 25
(12,523 Views)
I don't understand this question.
Use boolean logic.
Or do you actually need the index of the value that is TRUE.
Message 4 of 25
(12,520 Views)
So far we assumed that you have a 1D array (you did not say!)
(In the more general case, this idea would help too, but it does not seem to get a lot of love. 😉 Only 16 kudos 😞 )
Message 5 of 25
(12,513 Views)
Define "find the only one that's true"
Does that mean detect that there is a true in the array?  Or you want to know the location of the true in the array? Are you searching a 1d array?
Search 1d array on the array pallet if you want to know the location if it is a 1d array.
Or Array elements if you just want to know if there is a true value in the array.
Message 6 of 25
(12,507 Views)
Gosh, I do that all the time. +1 for sure.
Cheers
Message 7 of 25
(12,495 Views)
The sentence "find the only one that is true" implies that there is exactly one that is true, so finding it implies getting its index. We already know the value and that it xists exactly once.
The only complication would be in the case of higher dimensions, but he only gave a single number of elements, so it is probably 1D.
Message 8 of 25
(12,490 Views)
I want to find when it's true (1) so I tried to put 1 into the element node, but it asks for some sort of array. So I'm just confused about this.
Message 9 of 25
(12,486 Views)
I'm sorry it's a 2D array.
Message 10 of 25
(12,456 Views)
