find breakpoint programmatically
Hi Altenbach,
I have been doing that method, in fact i usually remove all my breakpoints as soon as i have finished with them.  However as i said in post #3  The only problem is my memory!  However thanks to ben i have found what i have been looking for, which is ideal for my situation.
Failing that the other option would have been a huge dialog box telling myself to remove all the break points.  I swear id lose my head of it wasnt screwed on.
Craig
Edit - replaced crass version of losing my head if it wasnt screwed on with more pc counterpart.
Message Edited by craigc on 09-14-2007 10:07 AM
LabVIEW 2012
Message 11 of 21
(2,727 Views)
It might be really useful if a VI that contains a breakpoint somewhere in the hierarchy would stand out in some way. Maybe the run button should have a red color or frame, or red run arrow, for example.
 (Suggestion!)
There is always the product suggestion page. 🙂
Message Edited by altenbach on 09-14-2007 08:35 AM
Message 12 of 21
(2,717 Views)
I beleive "Show Warnings" will reflect the Breakpoints being set.
All you have to do is WRITE PERFECT CODE to be able to use that option. Smiley Wink
Ben
Message 13 of 21
(2,706 Views)
Altenbach,
That would have saved me many a blood sweat and tear!  I think you should definitely suggest that, i would do it for you but that would be plagiarism he he.
Craig
LabVIEW 2012
Message 14 of 21
(2,703 Views)
BEN - "All you have to do is WRITE PERFECT CODE to be able to use that option. "
LOL, write code is a good start for me 🙂  I have had to re-write a lot of my code after i came across the gold rumberg thread. (Forgot his name - see i told you my memory sucks)
LabVIEW 2012
Message 15 of 21
(2,697 Views)
"... the gold rumberg thread..."
Thats fine. I'm dyslexic so my brain automatically unscrambles that text as "Rube Goldberg". Thank you for accomodating me. Smiley Very Happy
Ben
Message 16 of 21
(2,694 Views)
lol, No problem,  Thanks for reminding me. it will stick eventually, however breakpoints and names are sort of low down in the "committ to storage" priority list.  (Although i think the remove breakpoints should be moved up the list a couple of notches)
LabVIEW 2012
Message 17 of 21
(2,689 Views)
SImilarly, it happened to me in the past that I had a subVI left in execution highlighting mode and was really puzzled why my toplevel was suddenly so slow. I this case, we could have a yellow run arrow on the toplevel to indicate that fact. 🙂
Message 18 of 21
(2,684 Views)
Yep i have had that before as well, it doesnt help that the sub vi had a while loop in it homing in something to the nth degree!  As you say a yellow arrow would do the job.  Mayby a orange (Red and yellow mixed) arrow if there are both! 🙂
Its just really frustrating knowing you got to wait another day to do any "real" work, i came in to work in the morning and there was no data to look at! so my day has been setting off the program again minus one little Break point and watching it go while doing paperwork on the side.  And believe me paperwork is always my last priority 🙂
LabVIEW 2012
Message 19 of 21
(2,676 Views)
Orange if it uses 'Retain wire values' because of the excessive memory use.
Blue if it uses scripting
Ton
My LabVIEW Ideas
Message 20 of 21
(2,646 Views)
