find value in infinity
Hello all,
it is long ago as I learned it in the school, that's why I ask here, hoping a quick solution.
I have a measurement waveform (see attachment), and I want to know the value of its function in infinity. I just want to record the beginning the signal, maybe 2 seconds. There must be a math function, which results the theoretically value after 1 hour (basically infinity).
Thanks in advance
Madottati
Message 1 of 8
(4,268 Views)
Hi Madottati,
you could use any of the interpolation functions. Then use the output of those functions to extrapolate an expected value i for large x values…
And don't use the word "infinity", when you talk about large values!
Message 2 of 8
(4,250 Views)
Hi Gerd,
could you please create a small example for me. It must not be complicated, but with an example it would be much faster.
Madottati
Message 3 of 8
(4,243 Views)
Hi Madottati,
LabVIEW comes with a lot of example VIs. The example finder also has examples on the search term "interpolation"…
Message 4 of 8
(4,234 Views)
Interpolation is not the problem, but finding the value in infinity. I haven't found any example for that.
Madottati
Message 5 of 8
(4,213 Views)
Hi Madottati,
the interpolation functions give you interpolation coefficients. With those coefficients and the formula used by the interpolation function you can calculate your desired extrapolated value.
For an example you may read the LabVIEW help for the "Exponential fit" function…
Message 6 of 8
(4,187 Views)
Look into the Mathematics->Fitting palette.  Those may be able to find you an equation based on what data you have and then calculate with whatever value you want.
Message 7 of 8
(4,174 Views)
From the appearance of your graph the Exponential Fit.vi in the palette crossrulz mentioned might be a good starting point.
Lynn
Message 8 of 8
(4,125 Views)
