find variable name for ini file
Thank you all for the input. I have a better understanding of the config files now. I am planning on distributing this to many computers. What would you recommend I use for the path of the config file? I know in Labview 2010 I could use the build path VI with the application directory VI and a default file name conecting to it. The problem is is that I can only build an exe on my Labview 7 express version and there isn't an application directory VI. Is there anything in LV 7 express that would be able to recognize where the exe is stored and look for the config file in that folder?
Message 11 of 14
(612 Views)
I would just stick it in the same folder as your .exe on the Program Files directory that it gets installed to.  This path won't change from one system to the next.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 12 of 14
(602 Views)
I thought that at first but some people like to switch directories and I just might want to take that into account.
Message 13 of 14
(590 Views)
I don't know if LabVIEW 7 Express has the Get System Directory or not. If so you could use that.
LabVIEW 2012
Message 14 of 14
(584 Views)
