find whether an array contains an element
Hi guys,
This seems like it should be really easy and obvious... but I want to search a number of 1D arrays for a particular element.
I want to output the other values in the array if the element is found, and nothing if it is not.
eg. Input:
1  2  3,
2  3  5,
5  3  7,
3  8  9
Search for: 5
Output:
2, 3, 7
Even a simple T/F output for each array would be ok, I could probably do the rest.
Thanks!
(4,293 Views)
Interesting!  That was a bit tougher than it looked at first.
I'm almost positive that this code will show up on the Rube-Goldberg Thread.   It works though.  (There almost has to be a way to do that in one loop)
(4,274 Views)
Jeff second for loop where you are using equal function and again building the array of boolean.
Without for loop its same
(4,248 Views)
My solution, there's no removal of repeated numbers, i leave that to you.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,235 Views)
Here's my solution, based on both of yours above, and the fact that each row contains only 3 elements. (If anyone's interested I'm using it to find nearest neighbours in a Delaunay triangulation)
I tried to make it simpler... but I may have just Goldberged this even further...
Thanks guys!
(4,205 Views)
You know that "index array" is resizeable, right? 😄
(4,192 Views)
