finding a function within Labview
Using Sound and Vibration Suite and I am not a S&V specialist.  Trying to calculate the frequency of max power but can not find a function to do this directly (am I just missing it).  I am using the Power Spectrum VI and it seems I should be able to get it from that resulting info.  Any suggestions?
(2,753 Views)
The power spectrum VI returns an array (or you should be able to get it from
a returned waveform), Use Array Max & Min to find it's maximum, and the
index of the maximum.
Wiebe.
(2,746 Views)
Once you use the Max/Min VI I am assuming you will want to compare to find other "close" maximums thereby giving you the frequency of your max.  There is also a Waveform Peak Detection.VI that might be what you are looking for.
Sincerely,
Jason Daming
http://www.ni.com/support
(2,720 Views)
