finding ascii value
Hi All,
Although I think this is a silly question, I would still like to know how can I find the ascii value of a particular character entered in a string control.
e.g. the Ascii value for 0 is 48, a is 97 and A is 65
Thanks in advance.
Message 1 of 13
(5,500 Views)
Here you are
The type Cast function can be found in the "Advanced > Data manipulation" subpalette
Message Edité par chilly charly le 12-27-2005 10:02 AM
Chilly Charly    (aka CC)
Message 2 of 13
(5,499 Views)
Hi CC,
I tried doing the same, but I couldn't get the proper answer. Find attached the vi.
Message 3 of 13
(5,495 Views)
Sreedar,
You have represented type as I32, change it to U8
Regards
Dev
Message 4 of 13
(5,492 Views)
Just change the representation of your constant to a U8 since the ASCII value is coded on a single byte. Otherwise LV pads the additionnal bytes with zeroes, leading to a wrong value
Message 5 of 13
(5,496 Views)
Thanks Dev and CC for your help.
Message 6 of 13
(5,484 Views)
Hi CC
What is the major advantage in using type cast for any string to ASCII U8.Other than Using thiz LV function
Converts a string into an array of unsigned bytes. Each byte in the array has the ASCII value of the corresponding character in the string.
Message 7 of 13
(5,448 Views)
There is no  'Major Advantage' as such, of using 'type cast' over 'string to byte array' function.
The requirement in this case was to display a single string's ascii equivalent, hence typecast( which only converts first element in the string) was used.
If finding the 'Ascii equivalent' of a each element in a set of string characters was the requirement, then 'string to byte array' function would be a better choice.
regards
Dev
Message 8 of 13
(5,444 Views)
Hi guys
I'd use the "string to byte array" function, because I think it is not such a good coding, if you cast a string to a single U8. If you could enter a single character - ok, but as this is not provided, I'd suggest to use the mentioned function.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 9 of 13
(5,437 Views)
becktho a écrit: ...it is not such a good coding, if you cast a string to a single U8. If you could enter a single character - ok, but as this is not provided...
I'm curious. Is there a technical reason behind, or is this just a personal opinion ?..
Message 10 of 13
(5,410 Views)
