finding the average between 2 cursors
this is my vi, the only way i know of to save data from a test is as a csv file and i dont think thats what you are asking for
Message 21 of 22
(505 Views)
There is absolutely no reason to attach the same VI a second time. Once is enough!
Do the following:
  1. Run your VI until the xy graph contains typical data.
  2. Stop the VI. (The graph still contains the data).
  3. Go to the diagram and right-click the graph terminal and select  "create constant".
  4. Now we have a diagram constant that contains you graph data.
  5. Delete everything except the graph and the new diagram constant, save the VI under a new name, and attach it here again.
Message 22 of 22
(502 Views)
