finding the displacement from the accelerometer signals using integration block
hi
I am using the LabVIEW for finding the displacement form the accelerometer signals by performing integration, but when i am recording the displacement signals, it is aligning with the time step data number intend of aligning with the time steps.
I am sharing the block diagram where i am using the DAQ assistance for taking the data from the accelerometer and laser sensor. can you please help me to correct it.
thank you.
(1,358 Views)
Hi imran,
No.
We cannot edit/run/debug images in LabVIEW.
Even more when those images mainly show ExpressVIs…
(1,332 Views)
I am attaching the VI file. here I am using the accelerometer and laser sensor and performing the double integration for finding the displacement form the acceleration signals, I am also using the curve Fitte block for removing the ramp from the integrated signal.
 from this I am getting the displacement, but that displacement is aligned with the data point not with the time steps that i am giving to the integration block. I want to get to be align with the time steps.
(1,310 Views)
So you are reading some data, subtract the mean, double integrate using some crazy Rube Goldberg construct, subtracting a 5th order polynomial and expecting a reasonable value for the double integral of the data? IMHO, there are too many cooks messing with the raw data.
Can you show us some typical raw data?
(Most non-beginners typically stay away from express VIs and dynamic data. I am sure this could be done right without any express VIs with code the size of a postage stamp. Why not place all traces on one graph? Why maximize the diagram and front panel to the screen?)
(1,266 Views)
See if this can give you some ideas....
(1,255 Views)
That's a pretty big postage stamp.  😄
Bill
CLD
(Mid-Level minion.)
(1,209 Views)
