finding the index
hi,
we are trying to work out the bandwidth of S11 parameter of a resonator. firstly if you know the curve fitting equation would make this alot easier as we dont :-s
otherwise we have made a discrete plot of the curve and have found the magnitude of the 3dB marker, which has a corresponding index, we need to find this index
to relate it to the frequency (x co-ordinates). i did not write the program so i have no idea  about most of the program, but i have attached it. any help would be very
much appreciated
matt.
(2,709 Views)
Hi Matt,
If you are able to find the index of the 3dB point in the y-data of your xy graph then the same index in the x data will return the frequency at which this point occurs so just use index array in the x data array and it should return the value you require.
EDIT: Re-reading this post Im not sure if you have found your index yet!  There is a function to search a 1D array in the array pallette.  You can search for your -3dB point using this and it will return its index.  I have attached an example of this at work.
Hope this is what your after.
Message Edited by James McN on 08-05-2008 01:50 PM
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(2,705 Views)
