03-15-2012 11:32 AM
I have LabVIEW 2011 installed on my laptop, or it might be more accurate to say that I did have it installed until my computer crashed a few days ago and I am now trying to restore my information back into a new computer with a complete new install! So, one of the things that I would like to do is to find the file that contains the "favorites" information in the help menu so that I can copy the file into the correct place so that the newly installed LabVIEW will populate the help file utility with the previous listing of the favorites in the help utility. Does anyone know where this file is installed and what it's name is? Also, it would seem that there is another file which I would sure know about for the configuration af the devices and tasks that were setup in MAX. So, does anyone know where this file is located so that I can have MAX configured the same as I originally had configured before my computer crashed?
03-21-2012 03:16 PM
Hi Cuthbert,
To be able to recover your MAX configuration you should try to follow the process of removing MAX Database Corruption.
You can look for the path where the folders are in the computer that crashed and then copy those to the new computer.
