finding y-intercept of graph at any point
hello : )
    im attaching a simple vi of xy graph in the attached file..
an array of x-axis and y-axis points is also shown..
now i want to find the y-coordinate (y-intercept) of the graph plot at any x-axis point..
i have used cursor for this which works very well for x-axis values defined using arrays..  the problem is it does not shows the right amplitude for x-axis value not defined using array
eg.:- it shows amplitude of x-axis point 5 as 8 but for 5.4 also it shows amplitude as 8 which is not correct..
so is there any way or alternate method to find the y-intercept precisely
(3,454 Views)
Accepted by topic author gargrahul
Hi gargrahul,
try this:
Keep in mind: the X values have to sorted in order to have this piece of code giving you the correct Y value…
(3,442 Views)
GREAT GREAT GERDW !!! IT WORKS PERFECTLY WITH REGARDS, RAHUL GARG
(3,413 Views)
