fingerprint security
Has anybody tried to use some sort of fingerprint security with a labview application. We have a need to keep an application secure for only certain users to use. I know a password would do it, but am just wondering if a fingerprint scanner has been used. I basically will have an app that opens and asks for your login, once you login with the fingerprint scanner you can use the app.
Bryan
(4,639 Views)
That depends on how the scanner communicates with the computer.
If it has a DLL, and you know all the function calls, you can use the Call Library Function node to call that DLL.
If it has some other method of communication, it most likely can be used through LV.
Try looking at www.visecurity.com. They might have something.
___________________
Try to take over the world!
(4,629 Views)
Hi Bryan;
Yes, I do that. Check our products at www.biometricsview.com
Regards;
Enrique
PD: Thanks tst!
www.vartortech.com
(4,618 Views)
Thanks both of you for the input, I have already email vi security, and that will solve my problem.
Bryan
(4,601 Views)
Enrique,
Very nice and interesting products..
It is always good to know who does what..
(4,586 Views)
