firewire camera not found in MAX on Windows 7
Hi all,
Used to run a firewire camera on Windows XP with no problems. Using version 8.6 and do not want to change this if at all possible. New lab PC runs windows 7 and firewire camera not found in NI MAX. The drivers associated with the camera are NI-IMAQdx IIDC...
NI-MAX does not even show a NI-IMAQdx camera and there is no way to add such a camera. The same issue arises for an AVT Guppy camera suggesting it is not camera dependent.
Has anyone any suggestions as how to rectify this. We have full development software v8.6 with all the appropriate drivers and modules required as it previously ran problem free on an XP machine.
Cheers,
leeser
(2,881 Views)
Hi Leeser,
Which version of the driver did you previously have installed under Windows XP? It would be worth trying to re-install the latest version of the NI-IMAQdx driver. You will be able to install the Vision Acquisition Software 08.2010, which works with LabVIEW 8.5 and later (and installs NI-IMAQdx 3.7).
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
(2,866 Views)
