first time installation PXI-4472 in MAX device and interface icon
i have controller PXI-8176 and PXI-4472 card i have a problem after given the IP to the remote targer when i expend the device and interface icon of MAX my card PXI - 4472 does not come in the icon i just want to know how can i program the PXI-8176 and PXI-4472
(3,121 Views)
Did you download the DAQmx driver?  This will be necessary for the system to recognize the PXI-4472.
h_baker
(3,099 Views)
hellow h_baker
im using DAQmx (version 8.6).  h_baker i have given the IP Address to my target but the module  NI PXI-4472 and NI PXI-6052E does not come in divice and interface icon i want to program controller PXI-8176 with the module PXI-4472 and PXI-6052E.
waiting for ur reply.
(3,085 Views)
Did you deploy the driver to your controller?  If you right-click your PXI system under Remote Systems in MAX, then you should have the option to Add/Remove Software and deploy the driver to your controller.  See this link except you will expand Remote Systems rather than Software.
h_baker
(3,060 Views)
