fischertechnik libraries reporting missing functions
I am completely inexperienced LabView user on a FIRST robotics team. Since this question does not pertain to FIRST, I will ask it here.
I am using some libraries my teacher procured for using Fischertechnik RoboPro(?) robotics modules with LabView. The library parts seem to work until I try to insert them into a VI Block Diagram. Then they report errors with functions not being found in a cvi dll (not sure of the name as I cannot remember it, sorry). How can I repair these problems?
(2,785 Views)
Hello!
Could you be a bit more descriptive about the problem you are encountering?  You mentioned that it seems to work, but not when you put it in the block diagram?  So when exactly does it work?  What error codes are you receiving?  With this information we will be able to better answer your question.
Also, please note that as a FIRST member, you will be able to post to http://www.ni.com/community/FIRST and that any questions posted there will be answered by us as well.
Have a great day!
Kameralina
(2,756 Views)
