fit the front panel to window size
I am trying to fit the front panel to the window size. I already play with "window size" (set to current window size, size the front panel, ...) in VI properties, but I do not see any difference. My front panel is too big, I need to use the scroll to access every buttons.
My front panel used to fit well. I did add some buttons and a chart but I am not sure that it is the root cause. I did try to remove the buttons but the front panel is still too big.
In the front panel all the buttons, LED are bigger than it used to be before.
Thanks for any suggestion.
Laurent.
(2,952 Views)
Hello quimper,
I guess you checked the below checkmark in the VI- Properties Dialog. The other way would be you did it in the context menu of some control on the front panel.
If you want to have your front panel opened at a certain size, it only have to be saved in the desired size. If you always want to open it maximized, look at the VI-Properties at page "Window Runtime Position".
Greets, Dave
Message Edited by daveTW on 07-11-2006 11:36 AM
Greets, Dave
(2,944 Views)
