fits format conversion: need help...
My CCD is saving image as .fits format, a format quite popular among astronomer (I am not an astronomer though).  I believe that it saves as 16 bits unsigned data.
I have to do some array manupulation. I believe that since ccd saves array as binary, I may have to do the following steps:
(1) Convert binary array to floating point array.
(2) Do the array manupulation for floating point arrays:
C(ij)=A(ij)*B(ij)--> not matrix multiplication, just corresponding element multiplication.
(3) Find out C_max, C_min of flaoting point array.
(4) Rescale the array C.
(5)Storing procedure: Changing header, converting C back to binary arrays.
Well, I must say that  I do not know much about header in a particular format and how you can access it and change it etc..?
Also I was curious if I can do the matrix multiplication directly (not the one I have talked about before) without using loops.
Dushyant Kumar
(3,562 Views)
Hello Dushyant,
some answers:
(1) What do you mean by "binary"? You said before it's a u16 array... You can use those u16 values and make your calculation with them (or change them to sgl/dbl, whatever fits your needs).
(2) Labview can do this element by element math. It's standard for arithmetics with arrays. Just wire both arrays (A, B) to a multply node and you're done. (Both arrays should have the same size...)
(3) There's a min/max-node in the array palette.
(4) Same as (2): rescaling is mostly multiplication/adding.
(5) Don't know about FITS format, could not help you on this.
(3,551 Views)
Thanks a lot fot your help.
However, I do not exactly need help regarding  arithmetic. I would be fine with that. I put the details of arithmetic just to make everything explained clearly.
However, I do not have any idea of how to handle fits format and its header (I never dealt with formatting before).
I really appreciate your sincere efforts of helping me.
I believe that some astronomer may be able to help me as "fits" is quite popular in astronomy.
DK
(3,542 Views)
As of now, I have not been able to sort out the way to read the fits file in labview and save the manupulated array back as fits image. So, any help regarding that would be appreciated..
Dushyant
(3,516 Views)
Not sure if you've seen this page or not.  But it looks like it might have some good info and tools for you.
http://fits.gsfc.nasa.gov/fits_viewer.html
Patrick Allen: FunctionalityUnlimited.ca
(3,515 Views)
Thanks for providing me link.
It seems to me that for data-analysis I should prefer not to use labview. I will use IDL for analysis and I believe that there is some labview nodes for running IDL script. I would have to look for that info.
Thanks again,
DK
(3,510 Views)
