fitting multiple gaussians to curve
The most important initial parameter is the location.  I've had good results using the peak detector to locate the peaks and estimate the amplitude.  If the peak detector is inconsistent try filtering/smoothing your dataset first, then peak detect to get amplitude and location initial parameters.
-Jim
Message 11 of 11
(500 Views)
