fitting of a curve containing definite integration
I  want to fit a curve of the equation T=(1/(SQRT(pi*q))* intgral (-10 to +10)[(1+q * exp(-a*t^2)*dt
Certified LabVIEW Developer
(3,637 Views)
Use the nonliner curve fit with the VI model mode.
You need to create a model VI from the template (check the online help). It should calculate an array of T for an array of independent variables, given the parameters.
You need to be more specific. What  are the fitting paramters? What are constants? What is the independent variable?
(3,621 Views)
Thanks a lot for your kind reply.
Actualy the  variables in the equation is calculated using other equations.Suppose q is fitting parameter all other are known ,I want to know how to do the integration from -10 to +10.Would you please help me
with regards
augustin
(3,609 Views)
I am still confused what your "x" is?
You could just calcualte an array of values for t=-10..10 of sufficient density and the feed it to "numeric integration" to get the integral.
(My analytical math is a bit rusty, but maybe there is also an analytical solution for the integral. Maybe I 'll try Maple when I get a chance) ;).
(3,605 Views)
Could you also correct your formula. The brackets don't match up.
(3,600 Views)
I believe the definite integral of 1+ q*exp(-at^) is (sqrt(pi)*q*erf(sqrt(a*t))/2* sqrt(a))+t
(3,594 Views)
thank u  now i think i can do the thing ..i willl send you  the result
have a nice day
warm regards
augustinmj
(3,580 Views)
