fixed boundaries for a graph
hello
I have written a Labview application which collects data (counts of a
photomultilier) at different positions. these different positions are
changeing continiously.
I want to display the graph during the measuring procedere and (thats
the important part) I want to see the hole range.
at the moment the x-axis is growing and the y-axis is on autoscale,
but I want to give the range of the x-axis before the measurement
takes place and want to see the development of the y-axis (here
autoscale is OK).
thanks
alex
(3,136 Views)
It`s quite easy.
Right-click on the graph and de-select "X-Axis->Auto scale X-Axis".
Now you can edit the lowest and highest values of the X-Axis and they will remain.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,136 Views)
shoneill wrote in message news:<50650000000500000097080100-1042324653000@exchange.ni.com>...
> It`s quite easy.
> will remain.
> Shane.
well
it's not quite easy
if I want an online graph this graph cannot get a fixed display (in
every turn of the loop it extends the boundary of the x-axis)
alex
(3,136 Views)
a.jeschke@iu-bremen.de (alex@iub) wrote in message news:<8031cc83.0307110017.7d088c9c@posting.google.com>...
> hello
> autoscale is OK).
> thanks
> alex
to make it more precise I want to give the wavefrom chart a fixed boundary
(3,136 Views)
Hi Alex:
The best way to do this is with the PROPERTY node. If you tunnel down though all the options, you'll find a parameter called Active X Axis. You can wire the MAX scale to an external value. If you haven't worked with property nodes, you're missing half the fun of Labview 🙂
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(3,136 Views)
If you want your chart to start a 0 and end at a fixed number every time, then use a property node to set x.min to 0 and x.max to the maximum number of acquisitions that you'll do. You will also need to clear the chart history before each run. This is also done with a property node and you wire an empty array to it.
(3,136 Views)
