fixed voltage, x axis time, y axis current(or Resistance)
Hi, I'd like to ask for help with Labview.
I'm using keithley 2450 and USB-GPIB.
The functions I want to implement are as follows. Fixed voltage values (voltage can be set as desired), time on the x-axis (start from 0 seconds, end from set time or number of data) Current (or resistance) on the y-axis. I want to store 1. time (data corresponding to the y-axis) and 2. current values (or resistance) in Excel at the end of each reading function (i.e., at the end of each loop).
If I press Start, I want to set the name of the file that will be saved to Excel, and if I press Stop, I want to save only the values for the loop right before. If you press Start again, I hope to make sure that I can save it as a new file again.
The functions above are difficult for beginners to implement? How many days will it take..?
The file I attached is Single read. I looked up other information and found that it can be implemented to some extent if I modify the attached file and loop.
But I'm such a beginner that it's very difficult to study. 😞
Any information is fine, so I'd appreciate it if you could give me some helpful advice. Thank you for reading...
(1,181 Views)
Accepted by topic author dfwfaef
Hi dfw,
As you are a "such a beginner" I suggest you to take the "Training resources" as offered in the header of the LabVIEW board.
Basically the same suggestion as I already gave you yesterday!
Once you proceed with those "Training resources" it will be easy to implement all that stuff.
Hint: Basically you can use a state machine approach to execute one step after the other…
(1,156 Views)
Gerd W,
Thanks a lot for your advice!
(1,104 Views)
