flashing array
When I ran the VI, it flashed the numbers in the order  I described. Changing the output of the Quotient and remainder function gets the LEDs to light in ascending numerical order - going horizontally rather than vertically when going left to right and top to bottom. (see attached editted file).
(Just aesthetics of a demo VI)
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 11 of 14
(1,654 Views)
Oh, that. Yeah, I knew that when I posted the VI. The VI was just meant as an example of using a loop instead of the sequence structure. To be honest, I still don't know what the poster is trying to do.
Message 12 of 14
(1,640 Views)
Problem with an array is that he can't put the buttons 3 cm away from each other as stated in his first post 😞
Unless he blind some elements out, but that will make the more more difficult to handle (I think).
Message 13 of 14
(1,631 Views)
Sure you can. Just need to, for example, customize a Boolean LED and make it look like a button. See attached for a simple example.
Message 14 of 14
(1,623 Views)
