flashing stacked sequence auto start and stop
Seems like this should be so easy but I'm stumped.
I want to use some flashing leds while some of my data is plotted but can’t figure out a way to programmatically start and stop a simple flashing stacked sequence.
thanks for any help.
Message 1 of 15
(4,175 Views)
Everyone will probably have a different answer for this.
I would probably call a subvi to load dynamically through vi server as a pop-up window and close it when required. This would allow the subvi to be displayed on screen and operate independently of the main vi.
ssk
Message 2 of 15
(4,159 Views)
If I understand just put that while loop with shift registers
and the stop linked to the end of the other while loop
jacques
Message 3 of 15
(4,149 Views)
When I create a sub VI out of my stacked led sequence, then put it in a test while loop, I only get 1 flashing LED.
Using a shift register, I don't see how I could programmatically start/stop the flashing.
seems like these simple thing get me stumped quite often!
Message 4 of 15
(4,140 Views)
send me you vi i'll try using shift register
jacques
Message 5 of 15
(4,125 Views)
From looking at your VI it seems that the flashing starts when the middle frame is entered. But you are asking about programmatically starting and stopping. What is to control when it flashes? You have a Stop button but no Start button.
Lynn
Message 6 of 15
(4,120 Views)
Message 7 of 15
(4,115 Views)
could you save as 7.1 ????
Message 8 of 15
(4,110 Views)
My main program is based on a flat sequence structure, and when I enter a certain frame there is a delay while my data is plotted, I would like to display some flashing “LEDs” during the delay, once the data is plotted and I’m ready to leave this frame I want I want to stop the flashing and continue with the last sequences. The problem seems that when I use a while loop to create the flashing I just get stuck there until I manually click a stop button. I guess it boils down to how do I programmatically stop a while loop?
Message 9 of 15
(4,106 Views)
OK. Then put the flashing in the loop with Stuff 2, which I presume is the one for which you want to show activity. I modified your program to do this. I also eliminated the sequence structure by using dataflow. You can probably get down to one loop by changing to a state machine structure.
If the flashing rate needs to be a different rate than the Stuff 2 logic, put the slower part into a case structure which only executes one time for every n iterations.
Lynn
Message 10 of 15
(4,097 Views)
