flat pannel decoration
Hi !
    I am trying to modify a vi. I guess the attached vi contain a flat pannel decoration and its size is fixed. I want to modify the size. I am not able to find  any option which could chage it.
(4,492 Views)
If you can post the vi in 9.0 or older version, I can try to look into it.
Kudos are (always) welcome for the good post. 🙂
(4,486 Views)
I openend the vi in LV 2010 and had the same issue.
Is this happening in all the vis ?
(4,479 Views)
Odessy27 i have attached in LV9
(4,478 Views)
Accepted by topic author ssnp
The size isn't actually fixed, it just seems that way because the decoration is locked. You will have to unlock the decoration using the group/reorder menu:
However, you can't directly select locked objects, so either use Ctrl-A to select all Front Panel objects, or left-click and drag a selection box over the decoration to select it.
For anyone else who stumbles on this question, here is the code to programmatically change the size of decorations (warning: physics has no answer for what happens when you run this continuously):
(4,473 Views)
It solved my problem. Thnanks
(4,447 Views)
