flatten to sring doesn't work properly.
Using LV8.20, found "flatten to string" function under 7.x function group. but it doesn't work properly in lv8.20. Is there a function "flatten to string" function in LV8?
Thanks.
(2,706 Views)
Not sure where you found the 7.x functions palette. I found the function under Numeric>>Data Manipulation.
NI changed some things about data representation and flattening in LV8, so if you want to work with old data, you should right click the function and select Convert 7.x Data.
There is a rant here about the palette being in a problematic location, but that will go into the proper thread.
___________________
Try to take over the world!
(2,684 Views)
Thanks tst and it works well.
(2,667 Views)
