flatten to string and unflatten from string help
hey... can someone please help me!!! I need a simple example using flatten to string and unflatten from string.. I am using Labview 6.1 but i can't find any example in the software. Thanks alot...
Message 1 of 9
(7,997 Views)
Flatten basically converts anything you give it to it's equivalent bytes in string form.
I use it all the time with TCP WRITE ( and unflatten with TCP READ)
If you have an arbitrary structure ( a cluster of stuff), how do you transmit it via TCP, which only takes a string? The answer is to FLATTEN it. Wire your structure into the ANYYTHING terminal of a FLATTEN function, and wire the outout string into TCP WRITE.
On the receive side, it's only slightly more complicated: Wire one of your clusters to the TYPE input of an UNFLATTEN function (so the function knows what the structure looks like). Note that the values in this cluster are unimportant, the function needs to know the TYPE of the cluster. Wire the received data from TCP READ into the BINARY
STRING input. What comes out of the UNFLATTEN function is one of your clusters !
(Of course, with TCP, if your structure is more than 1500 bytes, you have to break it up into two or more packets, but that's a side issue).
You could also use these functions to transmit an arbitrary cluster over a serial port or some other connection.
Steve Bird
Culverson.com
LinkedIn
Message 2 of 9
(7,997 Views)
Dear CoastalMaineBird:
I've been following the steps you have indicated, but I get an error when I try to send the numbers array resulting of flattening a especified cluster ("type string output" of the function "Variant to Flattened String").
After sednding the flattened data, how can I send the array?. I get an error when I try it, and this is necesary for being able to unflat the string received on the other side.
Many thanks in advance!
Dani
Message 3 of 9
(7,997 Views)
Please see this answer to your question.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000000EF60000&USEARCHCONTEXT_CATEGORY_0=_49_%24_6_&USEARCHCONTEXT_CATEGORY_S=0&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
Ben
Message 4 of 9
(7,997 Views)
> Flattened String").
All data is contained in the string, the type string is just an empty shell, telling the "shape" of the original data. Just create a diagram constant of the same data type and copy it to the receiving VI.
(See also 096.14&EXT=gif>this picture that I posted in this thread).
Message 5 of 9
(7,997 Views)
Hello guys,please i have attached below the server and client sceen shots of a simple TCP/IP communication i am trying to do.When i run both vis i get an error message saying "LabVIEW:  Unflatten or byte stream read operation failed due to corrupt, unexpected, or truncated data." Please can you look at both screen shots and let me know what i am doing wrong?if possible give me a step by step solution on what to do.Thanks
Osowoaji
Message 6 of 9
(7,000 Views)
Elimiate the typecast operations, they make no sense.
Convert your data to a 1D DBL array and flatten to string. Send via network. On the other end, unflatten the received string to a 1D DBL array.
Message 7 of 9
(6,994 Views)
Hi there and thanks for the reply.This is what i have done but its still giving me the same error message.I'm i still doing it wrong?
Osowoaji
Message 8 of 9
(6,984 Views)
Osowoaji
Let's try to keep the questions in a single thread.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 9
(6,981 Views)
