flickering progress bar
Hey everyone.
I have a small problem with progress  bars.
I want to use it as an indicator between -1 and 1 filling up to 0.
The problem is, that it flickers at values arround Zero.
I made property nodes to dynamically change FillStyle (Fill to value below, Fill to value above), added a second slider to fill to and also used case structures to check if values are equal (changed value of second slider to fill to to -0,01, if so)
In some cases, I don't know which, the bar fills all the way up to top (1) or bottom (-1) but I want it to fill to zero always.
Can you help me?
(3,417 Views)
It would be helpful if you could put together an example and post it.
(3,416 Views)
If it will help, I can post the vi I'm working at, but unfortunately I can't post the server it connects to.
It's a simulation for an ABS-System and I want to use the progress bars to indcate slack at each wheel.
Message Edited by Skyfox78 on 07-31-2008 01:03 AM
(3,412 Views)
I fixed my problem by changeing the fixed second slider to the one that indicates negative values. The first slider stops at 0.001 so I don't have to change "Fill Style" anymore.
(3,347 Views)
