float number
I want to display the float number, when i use the numeric indicator, it only display the interger. how can i find the float number.
thanks
(2,787 Views)
Right click on the control or terminal, then select "Representation..."
Chilly Charly    (aka CC)
(2,779 Views)
You may also need to change Format and Precision... which can be found on the same pop up menu as Representation or under Properties.
Lynn
(2,756 Views)
