float to integer
Ravens Fan wrote:
Try your code with a negative number and see if it makes sense.
Great catch!  Knew I had to hurry with you guys involved...Smiley Wink
 Now it works.  OP wants to deal with FP representations and Banker's rounding, so I'll let you guys handle it.
Message 11 of 25
(4,347 Views)
said:Here's a solution that should work for:    Any number,   Any base (decimal is base 10),    Any precision .
Sorry, this has gotten way out of hand for my application and
way too complicated for my application.  I've got my answer
that fits my data range.
Message 12 of 25
(4,343 Views)
Yes, I understand that, but is your solution flexible?
However here is a negative proof solution:
It is the first time I ever used the Sign functionality.
Ton
My LabVIEW Ideas
Message 13 of 25
(4,340 Views)
Here's yet another alternative for 3 digits (-99.9..99.9). If you don't need negative, simply delete the irrelevant parts. 🙂
This code assumes that the input is in the correct range, else you would need to also coerce the absolute integer to 0..999.
Message Edited by altenbach on 08-16-2009 12:52 PM
Message 14 of 25
(4,337 Views)
altenbach said: Here's yet another alternative for 3 digits
Yeah, this is what I ended up doing as described in a previous post, except without the for-loop,
which is a much cleaner implementation that what I posted in Float_to_Int3.gif .    Thanks.
Message 15 of 25
(4,324 Views)
Ton
Kudos for (s)he who finds the bug. (without re-coding it).
Ton
Message Edited by TonP on 16-08-2009 10:08 PM
My LabVIEW Ideas
Message 16 of 25
(4,313 Views)
The fact it suffers from the floating point issues, I don't consider a bug.  Is it a feature that all of the digits will be negative if the number is < 0?
Message 17 of 25
(4,303 Views)
It should not suffer from floating point issues, could you describe this a little bit more?
Yes, consider  '-13', that means -1 times 10 and -3 times 1.
It is also valid to negate the units.
Ton
My LabVIEW Ideas
Message 18 of 25
(4,287 Views)
Sorry if I am mistaken, but since I didn't code it you'll have to tell me.  I assume if you put in for example 1.4, you'll get 1.399 or something similar.  Not a bug, just a fact of life in floating point math.
All digits being negative is certainly fine, just not sure if it was the effect you were shooting for.
Message Edited by Darin.K on 08-16-2009 04:55 PM
Message Edited by Darin.K on 08-16-2009 05:03 PM
Message 19 of 25
(4,280 Views)
Zero sets all units to infinity.
Ton
My LabVIEW Ideas
Message 20 of 25
(4,245 Views)
