float to mantissa and exponent
that's my first post in the forum, I don't see the problem with my small VI.
I want to get mantissa and exponent from a float (with power of 10)
So I made the following VI but for some input values like 1E-11,1E-12,1E-13,1E-14 it returns 10.0 for the mantissa instead of 1.0
which is a real problem for the rest of my code.
If I look carefully during execution, I see that comparison  1 more or equal to 1 is false !!!
I suspect that 1 is not really 1.0 but 0.999999999
Any explanation ?
Message 1 of 9
(8,464 Views)
You will always have trouble comparing doubles with values that are very close to eachother.  There is no exact way to store decimal fractions in binary.  The round off is exceedingly small, but can cause problems as you have demonstrated.
Any reason why you are not using the builtin Mantissa & Exponent function?  You can find it in Programming>>Numeric>>Data Manipulation.
Message 2 of 9
(8,457 Views)
Thanks for your reply.
The built-in Mantissa & Exponent function returns power of 2 and I need power of 10 (I work with decades and Log10)
Message 3 of 9
(8,450 Views)
I made a little example, how you can avoid those iterative multiplying of small values. So it should be faster and more exact.
Greets, Dave
Greets, Dave
Message 4 of 9
(8,436 Views)
This morning a colleague suggested me a different way to do and it's exactly the same as you.
Problem solved
Thanks everybody
Message 5 of 9
(8,432 Views)
ello there..
i have some problems while using the mantissa and exponent. i want to convert hexadecimal value which is FF80000 to floating point. suppose i will get -0.1 but what happen is i will get 340282366920938463000000000000000000000. i have read some information on IEEE 754 format floating point number. i am confuse by the sentence of E is the two's complement exponent with an offset of 127 i.e. an exponent of zero is represented by 127, an exponent of 1 by 128 etc.
Message 6 of 9
(8,278 Views)
Hi gdah,
well, if your hex code is really IEEE754 then a typecast to SGL should do the trick.
But: FF800000 isn't -0.1 in IEEE754-SGL, it should be something like BDCCCCCD!
See attachment with examples!
Message 7 of 9
(8,266 Views)
thank you for yr information..but actually the data ff800000 is received from the hardware. i must get -0.1 to make sure my data response is correct. i didn't have any problem to receive other data such as 230, 3.0 ..but when it come with -ve value my data response become wrong. is it because of my coding of data response or because of the mantissa itself??..plz help me...i'm using labview 8.2
Message 8 of 9
(8,242 Views)
I received this question from Judy by Email, but because of probably public interest I post this here again:
Hi David,
I couldn't read the vi because i don't have vi editor.
Is it possible that you send it to me in a txt file for the solution you posted up there.
Is it written in C language?
This is the solution you put there:
http://forums.ni.com/ni/board/message?board.id=170&message.id=206482
Thank you very much for your help.
Judy
Hi Judy,
there are some things to explain. A file with the extension .vi is a so called „virtual instrument“, which unifies the User interface and the program logic in one file. There are many more properties a VI has. To edit a VI, you need LabView. You can download a free (limited) version of LabView here.
My little VI is shown in the picture below, the upper part shows the block diagram (program logic), the lower part is the front panel (user interface).
The code can be translated into some text based pseudo- code as follows:
//###############  PSEUDO CODE  ##########################
Var
            Float, LogX, Exponent, 10^x, Mantissa : Double;
Begin
            LogX := Logarithm_Base_10 (Float);
            Exponent := RoundToMinusInfinity (LogX);
            10^x := Power_of_10 (-1*Exponent);
            Mantissa := Float * 10^x;
End.
Perhaps you can use this to solve your problem.
Greets, Dave
Message Edited by daveTW on 02-28-2008 11:02 AM
Greets, Dave
Message 9 of 9
(7,860 Views)
