floating point to fixed point conversion :::what is the algorithem
hi member
i have number which is a floating ponit and i converted it to fixed ponit representation by use lab view to fixed block vi
i am asking what is the algorithem that have been used by the to fixed block vi??
best rgeads
hi ?Q>
(4,187 Views)
Hi Mangood,
May I know what the fixed block vi you are referring to?
Are you referring to this function: To fixed point?
http://zone.ni.com/reference/en-XX/help/371361J-01/glang/to_fixed_point/
KwokHow
Applications Engineer | National Instruments
Singapore (65) 6226 5886 | Malaysia (60) 3 7948 2000 | Thailand (66) 2 298 4800
Philippines (63) 2 659 1722 | Vietnam (84) 28 3911 3150 | Indonesia (62) 21 2783 2355
(4,150 Views)
yes
i asking what is the algorithem that can be used to convert floating point to   fixed point with out use this VI!!!!
hi ?Q>
(4,110 Views)
The details of the algorithm depend on the configuration of the "To Fixed Point" function (in Properties). With default values, this algorithm produces identical results. A fixed-point value is a lot like an integer, except that the first bit has a value of 2^(-n) instead of a value of 1. To convert a floating point to a nearly-equivalent fixed-point, you multiply the floating point by 2^n, then convert that to an integer.
(4,096 Views)
There's a good paper here which explains the structure of a fixed-point value - http://zone.ni.com/devzone/cda/pub/p/id/303
To clarify Nathan's response, basically, a FXP has N bits which are a regular binary integer and M bits for the fraction, which work just like the integer (you multiply and add), but the Mth bit from the point is worth 2^(-M), so .001 is (0*1/2)+(0*1/4)+(1*1/8) or 0.125.
___________________
Try to take over the world!
(4,059 Views)
thank you
hi ?Q>
(3,970 Views)
