07-13-2015 03:29 AM
I wanted to grep vales from a string
"$PRISTY,1,-1,6553,25.3,0,,,,0*1D3B"
I basiclly wanted first 5 values. (1 -1 6553 25.3 0)
If i use scan from string with match pattern $PRISTY,%d,%d,%d,%f,%d ---> i get "error 85"
I can grep first 4 values, using $PRISTY,%d,%d,%d,%f ----> but the fourth value i get is just 25 and not 25.3.
I think there is problem in greping floating point values.
07-13-2015 04:11 AM
Works fine for me. Maybe your local settings use the comma as decimal separator?
Try prepending %.; to the format string, i.e. use %.;$PRISTY,%d,%d,%d,%f,%d
