floating source or ground referenced source????
Hi all,
       I am trying to capture the current waveform for different loads using a current probe (across live wire) and NI USB 6259 BNC. Should I set the source type to be ground-referenced or floating source??? As the load and the computer are connected to the same power system I should consider ground referenced source but current probe also provides the isolation which may prompt to use floating source. I am a bit confused. Your guidance will be of utmost importance.
Thanking in anticipation.
Haroon
(7,464 Views)
You may find this link and this link useful, and without knowing more about your system, it is difficult to make a recommendation. You could try searching for current probe systems that have been done before and see how they are wired.
(7,416 Views)
