flow measurment using labview
flow meters signal cable is only one.I have connected the flow meter  cable signal with the the resistor as u told and then connected both of them to DI 0(oin 14).
Please see the attached file
Message 31 of 33
(1,229 Views)
You need to connect the COM port on the NI 9401.
A signal is always a two wire connection.
You connect the possitive to pin 14 ( DI0 ) and you connect GND/negative to pin 1 (COM).
And your attached file is missing.
Message 32 of 33
(1,219 Views)
Send your subvi(Detflow new)
Message 33 of 33
(1,021 Views)
