font display hex normal
Hi
I just don´t understand, why does Courier new font so strange things. If I display a string in hex, then it is good. If I change the view to Normal (so ASCII), then after each word, LV makes a line feed. Why? There are no line feed characters in my string, and with all the other fonts it displays a continuous string. Well, it is strange to me.
Look at the two display modes.
regards
Gyula
Message 1 of 8
(5,420 Views)
Hi Gyula,
which LV- Version do you use? Which OS?
I made a little VI which does the same like your VI. If it works, your string- indicator could be broken.
Greets, Dave
Greets, Dave
Message 2 of 8
(5,409 Views)
Hi
I use LabVIEW 7.0. The strange is that if I choose another font, it works. Only Courier new not. And I need that, what else? 🙂
Message 3 of 8
(5,402 Views)
What happens, when you make a new VI, place a new String-indicator and change programmatically the display-style. You understand, just doing the same with a new indicator. Sometimes it happened to me, that a control or indicator broke somehow and I only could fix it by placing a new one from the palette and made all the customizations again.
Greets, Dave
Greets, Dave
Message 4 of 8
(5,392 Views)
Hi Dave,
I have just tried it, but no change. I didn´t make new vi, just deleted the original string indicator and created a new one. The same happens.
Message 5 of 8
(5,384 Views)
And what, if you do something like this?
Greets, dave
Message Edited by daveTW on 08-21-2006 03:19 PM
Greets, Dave
Message 6 of 8
(5,380 Views)
Hi Dave,
I do exactly the same. I made a backup solution (from software side very ugly): when I change from hex to normal display, I change the font name too, from Courier new to Arial. But it is nevermind.
Gyula
Message 7 of 8
(5,370 Views)
I am afraid, this sounds like you have to reinstall LabView. If this happens with the other string indicator types too (the classic and the dialog and the 3D- palette) it seems to be something very deep in your LV- system.
Greets, Dave
Greets, Dave
Message 8 of 8
(5,358 Views)
