fonts.vi
Hello
Create an account and would like to do
font settings, font size, etc. here
Asked whether there ready Vi type, see Appendix.
(3,454 Views)
What are you asking?
I'm afraid your post makes absolutely no sense.
(3,439 Views)
(3,412 Views)
Hi kayfolom,
In that link you provided, there is an attachment with an example program in LabVIEW that shows how to use the .NET font dialog. If you would like some more information on how calling .NET objects from LabVIEW works, you should take a look at the Calling Methods and Accessing Properties of a .NET Class/Object Tutorial.
Do you understand how this example program works, or do you need to modify it to do something else?
Julianne K
Systems Engineer, Embedded Systems
Certified LabVIEW Architect, Certified LabVIEW Embedded Systems Developer
(3,382 Views)
Yes, I would like to help. NET objects from LabVIEW to
preview the file that I want to print using
while General report toolkin. I am creating a report, and before printing it
I would like to preview  him. How to do this using. NET objects from LabVIEW
(3,361 Views)
Hi Kayfolom,
Were Julianne's suggestions and link helpful? What part of it to you need help with exactly?
Were you able to try/work with her example?
Nathan B
(3,320 Views)
