for loop and while loop with empty array input
   I got a question with for loop and while loop.
   When an empty array constant (zero element) is connected to For Loop with "enabling index", there are no any interations executed in For Loop. But, If the For Loop is replaced with While loop, no problem.
LabVIEW 2010
(6,792 Views)
Accepted by topic author weitong
It's ok. I don't see any problem.
For the "For loop" when you connect the Array with Indexation the number of Iteration is set to the size of the Array. The Iteration number assigned to N (in your case 10) is ignored.
For the "While Loop" the number of Iteration is set by the Boolean Condition and the size of Array is ignored.
Paul
(6,782 Views)
Hi weitong,
please go through LabVIEW-Basics and the context help to learn about AutoIndexing behaviour:
A FOR loop iterates the maximum number of (size of autoindexing arrays) and (number wired to N)! In your case this will result in zero = max(size of empty array; 10)!
(6,781 Views)
@GerdW wrote:
Hi weitong,
The maximum???  DOn't you mean the MINIMUM?
If the number of elements in array =2
and N terminal is wired to 5
"I think" it will execute only 2 times
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(6,771 Views)
Thanks Bjorn,
of course it has to be "minimum"...
(6,762 Views)
