for loop indexing?
Is it possible to change indexing step in labView "For Loop" structure? By
default this value is 1, and I need to make a step value different from "1"
like in C example:
for (index=0; index < 100; index++) {}; // step=1
for (index=0; index < 100; index=index+3) {}; // step=3
Sergey Yakovlev, Berlin,
yakovlev@evologics.de
(3,299 Views)
All you have to do is use the while loop instead of the for loop, you can have any increment value that you want. Terminate the while loop when some test condition is reached.
(3,299 Views)
Or do the for loop from 0 to 33 (N=34) and use i*3 as index.
(3,299 Views)
Sergey,
To step by count of 3: Add a shift register pair to your for loop. Initialize the left register to 0. Wire the left shift reigster output and a value of '3' into an Add vi. Send this sum to your right shift register (for use in the next loop) and also send it out as needed for your application. This will be an increment of 3 for each For loop.
I just noticed Dennis has given a workable method with while loops, so now you have 2 options.
Good luck with it, Doug
(3,299 Views)
Hallo, Sergey,
Du (yakovlev) meintest am 21.09.01 zum Thema for loop indexing?:
> structure? By default this value is 1, and I need to make a step
> value different from "1" like in C example:
What about
j:=i*3
and i is incremented by 1
Greetings!
Helmut
Please excuse my gerlish!
(3,299 Views)
