for loop with stdout of all iterations
Hi
I have a for loop which calls an external script. The external script writes something to stdout. I'd like to see the stdout. I tried connecting a string to the stdout, using a concatenating tunnel. But it always only shows one line of stdout, not all of the output from the iterations. How can I achieve that?
(3,715 Views)
If it is sufficient to see all stdout after the loop has finished, simply wire to the right loop edge to create an array of outputs, one element/iteration and connect a string array indicator ob the outside.
If you want to see the array as it builds, you need to use a shift register and built he array there.
Alternatively, you could use a single string in a shift register and append one line per iteration.
(3,697 Views)
Thanks for your help.
I want to see stdout as it runs. So I use a shift register for now. But I still don't understand how I get all the output into one string indicator. I tried to use build array, but it doesn't seem to work?
(3,679 Views)
Accepted by topic author iviewlab
How about using Concatenate String?
=== Engineer Ambiguously ===
(3,673 Views)
Perfect, thank you! That is much easier and more straight forward than what I had in mind.
(3,666 Views)
Here is an even simpler versions:
(3,627 Views)
