for loop
    What is the P and C terminal in FOR Loop?
(3,800 Views)
(3,797 Views)
Place for loop in block diagram, Press Ctl+H (Help Window will pop up) and place your cursor on "for" loop which you placed in block diagram. In the help window you can find the clear explanation for N and i. Press Detailed help in Help window for more clarification...
And have a look on examples also...
Have fun 🙂
<<KUDOS ARE WELCOME>>
Step out of your comfort zone to experience the real you!
(3,790 Views)
It is interesting that the help for the FOR loop does not tell you about parallelism.
The P and C terminals are for parallelizable loops. There is an article on NI's website here. About parallelism and making loops run in parallel.
A default FOR loop does not show these terminals.
     Rob
(3,785 Views)
