forced draft tray dryer simulation and control
Hi, I'm currently doing a project for my university which involves building a virtual lab for the experiment of Forced Draft Tray Dryer.
the objective is to determine the drying rate of the solid and the critical moisture content.
the tricky bit for me is to simulate and controll the experiment as i do not know the DAQ's to use.
Temperature, pressure, humidity andweight of the tray has to be measured at time intervals.
if anyone could help or point me out to where i can find a solution, it would be of  great help
(3,010 Views)
you might find this useful. Also once you find the hardware that meets your needs, you can use Measurement and Automation (for example http://digital.ni.com/public.nsf/allkb/A8C7C36B567DA00C8625754500026747) to simulate the hardware and write a VI for it.
Kudos are (always) welcome for the good post. 🙂
(3,007 Views)
