Just a warning; this vi generates a blue screen on my w2k machine.
Wiebe.
"Dr. Imad" wrote in message
news:506500000008000000ABC30000-1077587809000@exchange.ni.com...
> This is (Reference#566521)and an NI application engineer is
> investigating the issue.
> However, I want fellow LabViewers to shed light into the issue and
> offer some suggestions.
> 1) Run the main.vi. With the "set serial port" button True, press the
> call button. Will call and open the Debug_cntr_mnu.vi, whose front
> panel is set to modal
> if an error is reported because the port no. is not found, the main.vi
> becomes the foremost window (not the debug_cntr-mnu.vi)
> The debug_cntr_mnu.vi should stay in the front.
> Note:you have to force it to report th
e error, by changing the port
> numbers (in global.vi) to non existing port in your computer
> 2)With the "set serial port" Set To False
> 1)From the LabView menu help, make sure that the
> "context-help-window "is open (selected)
> 2)run the main.vi, press the call button, the debug_cntr_mnu.vi opens
> safely and will be the foremost window
> Till here it is working fine.
> Now, put the mouse cursor on the title bar of the
> "context-help-window". Then the main.vi becomes the foremost
> window,and you cannot access the debug_cnt_mnu.vi
> It is happeneing on my computer sys, Petium 3, and win 2000, LabView 7
