formatiing a string or numeric control or indicator like a password field
Is it possible to format the field of a string or numeric, so that the output is all asterisks or dots (like a password)?
Ideally I would like to be able to change the format (ie hide/unhide) of the string or numeric programatically from outside of the VI.
Thanks for the help,
- Troy
(3,601 Views)
You can do this with a string but not with a numeric.
The Display Style property of a string can be used to set the password display mode.
(3,596 Views)
String control/indicator has a display style property, which can be set at runtime.
From the Labview help:
Sets the display style of a string object. Valid values include 0 (normal), 1 (backslash '\' codes), 2 (password), and 3 (hex). You cannot write to this property when the referenced string control has key focus.
Marko H
OptoFidelity - Enabling Smarter Future
Tampere - Espoo - Oulu - Cupertino - Redmond - Zhuhai
(3,590 Views)
